MA Audio AMP
Im working on this amp not sure what modle it is .
The power supply fets were all shorted . I replaced thoose all gate resistors checked fine.
But when i looked at the drivers on the board it looks like someone has replaced them at some point but there are 2 2SA1023's
Isnt one of them suppose to be a 1027? Cause with just power and ground connected it draws 60+ amp of current.
If 1 is suppose to be the 1027 how do i tell which location it goes in?
I figured out the problem in the supply part.
Now im rebuilding the output section.
The model number on this amp is HC4002.
This amp says it will do 4000 watts @ 1ohm Which i highly doubt.
How Do i figure out how much this amp really does ?
