LYNX Power Amp PCB Group Buy interest
I am very sorry, I didn't want to start a controversy, but I still see those capacitors (C105 / C106) connected "upside down"
Here is the pertinent portion of the circuit that lesherons posted in the first page of this thread, located at:
http://www.audio-circuit.dk/images/...203 Schem.pdf
C 110 also seem to "look down" but it sees zero volt, so I think there is no problem. It only looks weird...
Lynx PCB v.3
I`m planning to do a new Subamp for my A.P Rhea.
Originally it has an amp with 300W at 4ohm (2 x 8 ohm elements driven)
Will this amplifier meet my needs?
What power and filter circuit is recommended for use together with this amplifier
in such case?
regards,
ManU
Youll need at least 40 - 0 - 40V @ 9 Amp
With this supply voltage, 9 Amp is no problem. The amps are rocksolid as long as you have enough power for the amps. So 300W amp = 600VA tranny (per channel)
I've build 6 channels of these for my Orion and still going strong.
Have some boards left :)
