Luxman LV-111 schematic
Moderator
Joined 2003
Poking around in a Luxman LV-111 amp to find what the problem is with the inputs.
Can't find it.
No input works, except when connecting a signal to the cd-input and pushing the "CD-straight" button.
Any help will be rewarded with Belgian French Fries. :devilr:
/Hugo 🙂
I at least found the block diagram for the
LV-105u. Will it help? Perhaps.
Unfortunately I don't have a scanner, so I
can only summarize right now.
Looking at the block diagram, the CD direct
switch bypasses the Tape, Mode, Tone and
Balance controls. (The Signal Processor
In jack ought to also work, if the problem
is in any of those above-mentioned
controls.)
Another thing to check is that if you select
one of your other inputs, can you measure a
signal at the record outs? If not, it could
indicate a problem with the main selector
itself.
Drop me a line via email if you need
something very specific.
Best,
Erik
