Hello, I'm looking to simulate a potentiometer in LT Spice and while there are a few netlists available on the internet, getting Spice to use user-made or even downloaded files has been difficult. Has anyone had success with this?
Yes. I use potentiometer_standard.lib from the LTspice yahoo usergroup. Here's a post how to get it:
good circuit analysis program - Single Post
what is the use - do you need "live" control of ratio during sim or just a setable/steppable ratio?
for the latter just use the parametric value defintion for a pair of R with the curly braces, and a .param for the setting variable
R1 value = {10k*(1-a)}
R2 value = {10k*a}
with a spice directive like one of:
.step param a list .1 .3 .6 .9
.param a = .5
you can even draw a rectangle around the R pair if you like it pretty - without needing .asy, worrying about lib management
R2 value = {10k*a}
.param a = .5
