I plan to design a low noise bipolar PSU using newer through hole reg ICs. Apart from the TI's TPS7A47/TPS7A33 which are no longer available in TO220 package the next best regs I could find are the AD's LT3081/LT3091. The question is are they worth their price if I am not interested in programmable current limit and other additional built-in stuff? At the moment these regs cost around 7 ~ 8 Euro each.
Regards,
Oleg
Regards,
Oleg
Let me put my question different. Are there significant benefits in using these parts instead of LM317/LM337 for line level audio applications which justify the price premium? The problem is that PSRR of LT3081/LT3091 is only marginally better, if at all, than the PSRR of the LM317/LM337. Also at HF the PSRR of the LT3081/LT3091 is nothing spectacular. LT3081 is also not a LDO part. The only obvious benefit is significantly lower noise.
Have a look at D-Noizator: a magic active noise canceller to retrofit & upgrade any 317-based V.Reg., then decide.
