I have not tested, but based on the datasheet, it should work fine.
For 1 mA use 1k2 resistor between Vout and Adj. pins.
Be careful, the PSRR (power supply ripple rejection) only 60db!
I think that is the problem .
Other IC regulators.
https://www.google.es/search?site=&...0....0...1.2.64.psy-ab..2.1.190.0.OnU_sGqbs2M
Cheers
You'll be ok @1m the safe operating area of the LR8N3 is 0.74W in the TO-92 package. Working the math backwards Vin-Vout for 10mA = 74V
Higher PSRR -- DN2540N3G, or a pair of them will make you a source with MegOhm impedance. SOA bounded by 1W. It's also TO-92, cost is $0.78 vs $0.64 for the LR8N3. See the second in Walt's series on current sources.
Supertex is now owned by Microchip, Mouser carries.
Seriously ?
Usually a 100k...220k resistor is used at the anode of 12AX7 and is fine for most cases..
How much would the PSRR be with those resistors ?
In the end the usually cascode.
Other option: the LND150, maybe?
Thanks.
> Usually a 100k...220k resistor is used at the anode of 12AX7 ... How much would the PSRR be with those resistors ?
Without looking, say 6dB.
Knowing some about the situation, as much as -9dB.
As a general thing, the B+ to a volt-amp stage should be clean enough to listen to, "silent", at the signal level and subsequent gain of that plate.
If you want to cheap-out, you can let B+ racket be a little higher R-loaded, much higher with a stiff CCS. OTOH a good CCS is about as many parts as a good voltage regulator/filter, which can also drop B+ crap way down. As can simple R-C filtering.
I find them at TME Spain. Nice prices.
Cheers
A correction my tarzan-english
LR8 is more or less a high voltage LM317 and I suspect this , like the LM317 , will not make a particularly good CCS
Try LND150 instead , this should be ideal for a 1mA CCS load
316a
316a
316a
The LM317 makes an excellent CCS IMHO. Even Broskie says so.
- Tubes / Valves
- LR8N3 as load anode CCS
