You are looking at the voltage drop across the resistor.
You have not given much indication of what you are doing. If you are building an amp from scratch, you are probably doing the heater wiring first. If this is the case, wire up allowing for the addition of a dropping resistor. Put all your valves in and fire her up. Measure the voltage with the full load, and then use Ohm's law to calculate the resistance required for the voltage drop required. Use Ohm's law again to calculate the power dissipation of the resistor, then choose a conservative rating. Dsavitsk recommends doubling for safety...
V=I/R, R=V/I
So, to drop 1.2 volts (you may need a different amount when you measure under load) with 1.8 Amps, you will need 0.666 Ohms and dissipate 2.16 Watts, so go with a 5 Watt resistor.
Not sure what valves you are using, I have looked up heater voltage ratings and not many show a +/- value. THe Russian valves do, and usually have 5.7-6.9 volts listed, so if it is well inside this I would not worry, though higher voltage may lead to shorter valve life.
Chris
