Hi guys
Has anyone ever thoght of building a low voltage 'ESL'? It'll probably be more like a cross between an ESL and a ribbon. The idea being that you have a diaphragm similar to a ribbon, but the panels are driven by a low-voltage, high-current source. Something like a ribbon between two electro-magnets. The only thing I need to know is what influences the strength of the magnetic field- is it high volts or high current? Will two panels with high volts have a higher field-strength than two panels carrying high current? Just curious.
Thanks,
Deon
Thanks,
Deon
