Hi Guys
I’m looking to construct a low pass filter. Having done some research I can see it would consist of a resistor, in series and a capacitor in parallel.
Would it be possible to change the order that is parallel the capacitor first and then add the series resister. I was actually looking to use the input impedance of the amplifier thereby only using a parallel capacitor.
Would this arrangement achieve the same result.
It’s quite clear from the research that Ive done for a high pass filter that the capacitor is in series and the resistor (amplifier impedance is in parallel) and that works ok.
Many thanks
Many thanks
No, that's problematical as it presents a capacitive load to whatever drives it, which can cause instability.
Amp input impedances are sometimes not constant and well defined, and many amps assume a low driving impedance - so its often problematic to use a passive filter on the input to an amp, a buffered active filter stage is preferred.
Passive filters always interact with the source and load impedances.
