Low parts chip amp ?
The TDA7267 will deliver about 1.5 watts into a 4 ohm load with 9 volt supply. The LM386 can't really handle 4 ohm loads at 9v as it can only do about .75w under the same conditions. Either should get loud with an efficient speaker.
The TDA2003 requires a minimum 8 volts for proper operation, so a 10% droop in mains voltage will bring it too close for comfort. Having said that, many wall warts actually supply higher output voltage that specs under load would imply. I would measure voltage with the expected load and see how much the voltage actually sags, that way you'll know for sure.
Mike
Quite a number ask about practice amps for electric guitars.
Why?
When I was at University one of my peers carried around his bass guitar. Pulled up a seat and practiced any where. No amplifier needed.
And then just imagine how the tube screamer sounds, or the reverb, feedback, octaver etc. Then you could drop the guitar entirely.
For non-amplified rehearsal we have something called acoustic guitar😀
