which PSU do you recommend that has 19V 65W 3.42A. I need it to power this Pi-DigiAMP+ - IQaudIO Limited
I guess there should be better PSU-s than this VEF65US19 XP Power | Power Supplies - External/Internal (Off-Board) | DigiKey
I would suggest a couple of stages of RC after the built in LC filtering is required to get lower noise.
The added R will increase the output impedance and that in turn will reduce the regulation.
i bought too the IQaudIO Pi DigiAMP+. Was planing to buy the VEF65US19 and ultimately mounting everything under the same box. For a layman, what do you mean by adding couple of stages of RC?
Just use the XP part they recommend. It's a switching amplifier and they don't give any specs, I wouldn't worry about it for what it is.
OFF
Andrew!
Please tell me what do you call "regulation", because I saw earlyer you use this term regarding transformers in place of "drop", which is a voltage or relative voltage change, but here the meaning is reciprocal, less regulation means more voltage change. You can overdefine terms for yourself, but would be better if you didn't use 1 term in 2 opposite meaning.
I advise you to not use term "regulation" for defining quantities at all, since it is always a source of ambiguity. Regulation is a process, involving at least 2 quantities, and if you want to describe its goodness with a single quantity, then it should be a ratio of the change in target quantity and the change in affecting quantity. As you can see in datasheets, for example "load regulation" is given in %/A or mV/A.
