Looking for ultra simple audio player design.
Requirements are.
Stereo.
Input: any file like WAV, MP3, PCM, custom data format on SD card or EEPROM.
Input data will be prepared before end.
Output: Right channel, line level. Left channel,
medium/low power speaker.
Immediate turn on / off. In other word no implementation asking to wait for booting / shut down.
Wishes.
Low cost, using ready made proven modules.
Power supply included.
There are many solutions, from using parts reinventing everything up to using a microcomputer as long as, OS booting and shut down is not needed ( stand alone, using BIOS would be fine ).
I would like as little as possible hardware development. Programming is fine.
Ultra low cost is the challenge.
Having tried out a few of the very cheap MP3 players on Taobao, I've found this one to be the best overall. Most resilient in practice - you can pull the card out while it plays and it'll just mute for example - although a very long way from being the cheapest. In the general scheme of things though, $12.5 is incredibly cheap for what's on offer.
??/????WAV/APE/FLAC??AK4495???I2S?SPDIF????-???
Fully featured for sure, any idea of current consumption ?.
Dan.
From memory I think it was under 100mA (from a 5V supply) on my most recent purchases - it varies depending on whether you use BT or play from SD. I do recall when I first got my hands on one (over two years ago) I noticed that it ran fairly hot. But when I bought some again earlier this year the thing surprised me in that it ran pretty cool. Perhaps the firmware got an upgrade in the meantime.
What is the pitch accuracy from these very cheap MP3 player ?
I see no clock or external clock input. I fear, the internal clock oscillator is not so good.
I need better than 1%frequency accuracy.
On the DFPlayer Mini manufacturer site, I see the chip comes in two flavors where the only difference is, one has "high quality".
What different quality could this be ?
My guess is the 'high quality' one is new, the other is of dubious provenance. Could be a pull for example.
@Mark Tillotson - I took my verniers to the XTAL package on the CPU module, its 3.1mm * 2.4mm.
Pitch accuracy might be an issue with the cheap MP3 player I have in mind.
DFPlayer Mini.
YX5200-24SS MP3 Chip
DFPlayer Mini MP3 Player Module for Arduinio Manufacturer
As said in the OP, I need 1% accuracy.
This chip decodes mp3 using an internal clock. Who knows about this clock, presumably a silicon based clock, may be ceramic, not as good as a Xtal clock.
All I could find:
Maxim chips silicon based clock with 2% accuracy.
Ceramic resonator said to be 0.5%.
