Hi, I am looking models for next tubes (triode & pentode):
6J9P
6P15P
6J32P
6J49P
6J52P
6E5P (only pentode)
D3A
THX in advance
6J9P
6P15P
6J32P
6J49P
6J52P
6E5P (only pentode)
D3A
THX in advance
I just sent you a PM containing 6j9p, 6p15p (=SV83),6e5p and D3A models.
I think that you do not need any particular triode-models. Just connect g2 to a and go ahead.
thx
6J52P
THX in advance
Try these parameters:
MU=85 EX=1.5 KG1=63 KP=741 KVB=4700
and (omitting the case in which Vg1=0)
MU=100 EC=1.48 KG1=35.8 KP=445 KVB=2670
I think we both ran the tube rather "hot" -- mine shows Ia of 50mA@ Va=100, Vgk=-0.5, yours 40mA -- as you suggest the values are probably scattered all over the lot.
I couldn't get a good fix on the Vgk=0.
Yes, the variance is high. I only found one valve out of 20 to be close to the specs. This one is the one I traced
Ale
Ale
- Tubes / Valves
- Looking for LTspice tube models
