Looking for existing speaker design, 15+horn
Hi, I am new here and struggling a bit. I would like to build a pair of speakers to replace my 30 year old 15 inch 4-way party speakers. I am trying to find an existing design that uses a 15 inch woofer and preferably a horn loaded upper. These are for 2 channel audio. I am looking for dynamics, high efficiency, a live sound. I listen to rock, pop, and country. I have a size restriction of 19" wide, 29" tall and 21" deep, due to having to fit them into existing cabinetry. Any help would be appreciated, thanks.
A Peavey SP2-XT can be adjusted to the same volume (Fs). They come 21" wide, 31.5" tall, 19 deep. If you cut width and height, and increase depth, you can achieve nearly same volume. 1508-KADT woofer, RX22 1.4" CD on Peavey horn. You can usually buy the horns on ebay used, since bands usually blow woofers. 1200 hz crossover, 12 db/octave. See spec sheet from Peavey.
Such as calpamos, (which I understand is discontinued).
The files are still available. Corssover and cabinet drawings included.
The components are also still available so can be built easily.
Troels gravesen has his TL-1/2/3.
Faital 3 way classics etc.
Inconcert Miles and Duke, are available.
DIYRM / DIY loudspeaker project pad has a few designs in all the info that will fit.
Easiest to find through Facebook.
The Asathor was mentioned above.
You will find some similar designs on here if you dig around.
Osmc for example, if it fits your bill.
Zilch's Econowave speakers in different forms you will find plenty of info on here,
Linked the original thread below:
https://audiokarma.org/forums/index...esign-collaborative-econowave-speaker.150939/
You might find some suitable ones here:
https://www.lautsprechershop.de/hifi/journal_klang_und_ton_en.htm
If you don't mind the price, Joseph Crowe has some designs available too.
  • Thank You
Reactions: chirs and GM
Keeping the woofers sensitivity in the 97db range ( iow > high-efficiency along with a smallish box ), means a 15" Pro woofer of some sort.
- One will need to rely on a bit of EQ or LF Room-Gain to get a real 40hz response.
So, using 17"x27"x19" ( divided by 1728 ) one gets @ 5 cu' of box volume to play with.
I think the 4Pi box is around 5 cu' ( or maybe a smidge smaller ).
The JBL 2226H woofer model is mentioned as an option for the 4Pi and is an all-round great performer ( these come up for sale once in a while in the used market ).
Reactions: Arez
