Looking for best Tiny Low Power Stereo Amp
staticV3
2019-10-12 5:28 pm
Hi guys,
I am looking for an Amp board for a DIY Bluetooth Speaker.
I plan to stuff a T1-1828s and an ND25FA-4 into as tiny a wooden box as possible. Essentially, an oversized Toblerone bar. Frequency separation and equalization will be handled by an ADAU1701.
The one thing I'm struggling with is finding the right Amp board for the job. There is a ridiculous amount of designs on eBay and Ali and only a few of them come with actual specs. As a result, I'm quite lost.
I am looking for the best Stereo Amp with 5W+ RMS/10W+ max per channel into 4Ω drivers. It shouldn't be larger than 80mmx55mmx15mm. Smaller than that would be great.
I do not care about features like a volume knob, balance knob, etc. I only care about performance (Dynamic Range, SINAD, frequency response, ...)
As this is a battery powered project and thermal management will be tricky, efficiency is also important.
So far, this seems to me like a good contender, but I'm sure there are better.
I look forward to any suggestions!
staticV3
2019-10-12 5:28 pm
Thank you very much for the pointers! The only Amps with one TPA3118 per channel that I could find were quite large. All the smaller ones use one chip for both channels. There is the XH-M531 which is small enough and uses two YDA138s but as always, I couldn't find any specs :(. Lastly, it seems like Droking is the only manufacturer to use the PAM8620 and so there is barely any information about it. Mhm..
