philips dfa 1000
I also own one of these. I purchased the unit from one of the warehouses in NY from an add in Stereo Review. This is a refurbished unit from Knoxville, TN. My original unit died in '91 with this same problem. The tech guru told me it was a relay never to be found anywhere on the planet and sent me a replacement (said refurbished unit). He later told me that the problem with the unit I now have, was a blown fuse. He (technical guru) dissembled the entire unit, looked it over, decided afterwards to LOOK at the fuse, and wham o.
The only thing he forgot to do was replace the screws under the door with the original copper coated screws. I replaced them with aluminum screws, assuming these were supposed to be grounded with the base plate. I could not find copper screws.
My Philips has been a loyal friend for over 20 years but like others, one of the outputs just died. I am not sure why this is but I neither have the time, wherewithal, nor the technical abilities to deal with it. I know what the problem may be. There is a protection circuit that is causing this failure. My problem may be within the protection circuitry itself or anything that may cause heat buildup. If I shut down the system, unplug and wait 10 minutes or so, replug, restart, everything works for a short time, then shuts down again.
Other than my recent problem, the unit is in perfect condition, I have the original remote and the manual. I have used the remote one day. I just programmed it to everything else and it worked. I reset the remote to its defaults, removed the batteries, and stored it away in a plastic baggie with some silicone beads. I have no box, it weighs too much for most boxes to last more than one day. In my elder years, just moving this behemoth takes a lot of effort.
I am replacing my old friend. I offer my old friend to anyone who may have a need for it.
