like the topic stats
8" driver
high q design...perferably high .5+
decent x-max of 3-4mm+
decent sensitivity of high 80s+
3.5" or small mounting depth
$50 per driver is a nice starting price range i suppose
right now i was looking at the eminence alpha8 partsexpress has them for $34 a driver in a set of 4
8" driver
Maybe this one?
MCM 8" Poly
According to Pjay's driver finder this one's Qts is 0.72.
It's perfect for paralelling with its 16Ohm rating. And the price is right also- around $14.00. Personally I was considering it for a dipole project.
8 per side in a series/parallel configuration for a nice 8Ohm rating with high sensitivity.
MCM 8" Poly
dang i like everything about that driver, but do you happen to know the mounting depth? this is extremely important 🙂
it doesn't look like its over my limit but pictures can be deciving
No I don't know its depth. MCM has a Tech Support page where you can request additional information.
I suggest you start there.
Is the driver you're looking for going in a car?
Kan3:
Thanks. But he lists these drivers by F3, not Qts. Is that true, or am I missing a page off this website?
kelticwizard said:Thunau:
How do I find this Pjay's Driver Finder?
Pjay's site is Here
Another good one for finding drivers is at http://www.thielesmall.com/
kelticwizard said:Kan3:
Paste the data in a spreadsheet and sort by the Qts column.
Kan3:
A little higher price than you wanted, but a lower Fs than you were hoping for, plus a better Xmax and it suits your depth requirements, (3¾"). Or did you require 4 ohm?
http://www.partsexpress.com/pe/pshowdetl.cfm?&DID=7&Partnumber=296-208
Xmax is a little less than you wanted, but it is 4 ohms for the car, the depth, (Parts Express' "C" dimension), is right at 3 5/8" and everything else checks. Plus the price is nice at $13.
http://www.partsexpress.com/pe/show...6&St3=-61263437&DS_ID=3&Product_ID=7536&DID=7
Another nice one, seems to fit all your requirements. Price is $29. Available in 4 or 8 ohm. Depth is 3 11/16"
http://www.partsexpress.com/pe/show...6&St3=-61263437&DS_ID=3&Product_ID=7543&DID=7
All in all, Parts Express is selling a lot of *" woofers, especially Goldwood, which would seem to have both the numbers, the depth and the price you seek.
http://www.partsexpress.com/webpage.cfm?webpage_id=3&SO=2&DID=7&CATID=30&ObjectGroup_ID=489
It's discontinued, but the Audax AP210MO would also look good if you can find it. It's listed at $32.
Good luck!
Good luck!
- looking for a high Q 8" driver
