hi there,
i looking to buy four caps for my class a amp.
the specs are :
15,000 uf at least
64 v at least
diameter- 2 inch
length- 4 inch
brands: mallory and Cornell Dublier
if anyone has, please mail me at:
amirits@yahoo.com
thx
the specs are :
15,000 uf at least
64 v at least
diameter- 2 inch
length- 4 inch
amirits@yahoo.com
thx
if you can fit a slightly larger cap in its place check with zero cool in the trading post section. he has 15000 100v for a CHEAP price in my mind. BUT HURRY i passed on them and in our email he said they would soon be on ebay!
Hi.
Take a look at this. I don't know if they are still available, but its worth a try.
http://www.diyaudio.com/forums/showthread.php?postid=1443052#post1443052
Good Luck,
David.
Good Luck,
David.
the caps.....
thx for your answers.
the echowars caps are too long , i can fit up to 110mm tops.
as per the 64 vs 63... i got the sepcs from someone who understands. but i really don't know. 63 might do it.
thx
amir
thx
amir
United Chemi-Con, screw-terminal cap, 18,000µf 75V - 2" x 3.125" (50mm x 80mm).
Mfg. part number 36DA183F075BB2N, Farnell part number 4959796.
£10.39 each
http://il.farnell.com/
£10.39 each
thx echo
these seem like a great buy price wise and size wise....
do you know anything about this brand ?
i just don't know anything about caps, and i was told mallory and cornell are good.
do you think they are at the same level ?
if so, i think i will buy them.
the price is right.
thx
amir
the price is right.
thx
amir
If price is really that important, then do go to someone who knows (not that expert) and find out if you really need at least 64V capacitors.
Generally electrolytics of 63V and lower are much cheaper than 75V and above.
andrew
price is an issue, but not that much.
10-20 $ is ok.
the brand and the price combo is the thing.
amir
10-20 $ is ok.
amir
Re: andrew
are you using 8 or 12 for the two channel amp? i.e. +-30mF/channel (6ohm or more) or +-45mF/channel (4ohm)forte123 said:price is an issue, but not that much.
10-20 $ is ok.
amir
andrew
didn't quite understand...
it's a forte' 4a and it has 4 caps.
i am using an 8ohm speakers at the moment (proac 125).
hope this is what you ment...
Re: thx echo
These United Chemi-Con caps (which will arrive branded Nippon Chemi-Con) are superior parts to the Mallory and Cornell Dubilier ones. If they are the correct physical and electrical size for you, get them.forte123 said:these seem like a great buy price wise and size wise....
the price is right.
thx
amir
- Design & Build
- Parts
- looking for 15000uf caps
