Longer lead wire for SUMITOMO AWM 2896???
ok heres the deal i need to get a wire that will do the same thing as the one i have but i need it longer....as long as possible.....i have the lead wire it says on it SUMITOMO-M AWM 2896 80C VW-1.....its for a audiovox screen. I found the wire i need but i cannot tell what the size difference is and how big is it and i have no way to order it....so any help in this matter would be appreciated. THANK YOU
samwarr,
the two items you are suggesting are 22pin cables and the one mentioned below is a 40pin cable. I am looking for exact same spare part for my Mitsubishi WD-62525 TV.
I already downloaded the complete catalog from Digikey and the closest I found is HFF-40U-05-ND that has a 127mm long and 20.5mm wide with 0.5mm wire... $4.95. I am waiting for delivery to make sure it was the right one.
Rgds, RAC
