LM3886 with mute relay still popping ?
I added two relays as muting switches on my LM3886 amp, 12V / 16A Schrack units, powered from an independent small PSU, which is connected to a mechanical switch on the chassis, so I turn the amp on, and then unmute it.
The amp is totally silent during power on, but pops relatively loud when I mute it. Is there a way to reduce this pop, maybe by adding a "snubber" to the relay? I read here that this is exactly what reduces pops from a normal switch, but could someone tell me what values should I use for R and C?
Switch contact design : Switches
Please post a schematic. The most likely cause of the popping is a change in the output voltage between muted and non-muted states. The output voltage follows the voltage on pin 7 when the part is muted. It follows the voltage on the non-inverting input when the part is not muted.
If these voltages are different, then you get a pop. Of course, you'll also get a pop even if the only difference between the two is some offset voltage, but the pop should be smaller.
So....please post schematic, and perhaps I can refine my guesses and see if they make sense.
Akitika GT-101
