The datasheet say that there will be no power on/off transients or DC spikes. Can I trust this? eg if I use the chip to power an expensive tweeter in an active system?
One of the graphs on page 10 shows power of up to 75W into 8ohms with 40V supply. Tthe same THD+N spec as used in the performance section which is based on 35Vsupply and gives 56W.
So what is this region of greater than 35V supply? Is it not recommended, just for the brave ?
