Good afternoon all,
I was looking at a couple of LM317 calculators for R1 and R2.
Question. Is the VOut given in these calculators the voltage drop from the input voltage or the actual voltage output.
The Toroid tranny I have has a 17.8v tap so I was a little confused on what the calculator VOut giving.
Any help would be grateful
Cheers
Brian
Cheers
Brian
Good afternoon all,
Cheers
Brian
If you can give us a link to the calculator it will be easier to comment!
Sorry - They all seem to be the same.
Here you go.
LM317 / LM338 / LM350 Voltage and Current Regulator Calculators
LM317 Calculator
Brian
Here you go.
LM317 Calculator
Brian
As long as Vin is at last 3V above Uout. Input voltage does not matter.
But (Vin - Vout) and load current determine the power that will be dissipate in IC.
Pdis = (Vin_max - Vout_min) * Iload_max.
And without the heatsink power dissipation in IC can not be greater then 1.2W
- Tubes / Valves
- LM317 calculator for filament circuit
