Live Music Club Sound deadening/treatment
I am working on a project to convert an old dance hall w/balcony into a live music club. The starting sound is super hot/live and my goal is to deaden as much as possible.
The wall height is ~26' from the wood dance floor to ceiling. My vision is to make 4x8 boxes with 1x8x8 pine, with center support, and fill with rockwool. I assume I can double up the 4" rockwool to fill the void). I plan to cover in muslin and hang from ceiling 8" off the wall.
Should I alternate heights to compensate for the taller ceiling? What would be a good square footage of deadening panels that I should start with? Lastly, can I suspend these from ceiling/flat in the center at various areas to reduce reflection from ceiling?
Wall material is brick on 3-sides, and drywall on opposite of stage. It is a rectangular room 40'x100'x26' tall.
Goal to reduce as much reflection as possible (I will work on corner bass traps after testing room).
I suspect I will be coming here with many questions as I learn this process.
at 104 thousand cubic feet and no measurement of RT60 for the space i'd estimate that reverb time is like a hockey arena at 2.6 or greater seconds and absorption down to 160 hz is required to achieve the perception of "dead", that would mean that 3/4 of the surface area needs to be covered with mostly anechoic deadening...think anechoic chamber....material cost....priceless = very high....i hope that whatever entertainment your intending to run is going to offset the expenditure!!!
What kind of music will be performed?: Rock, country, jazz, "smooth" jazz, metal?
How loud do you want the music?
Will you have an installed system, or will musicians bring their own?
Will there be a dance floor, or tables, or a combination?
How high and how large will the stage be?
What is the current construction/finish of the ceiling and flooring?
With this information, I might be able to offer some suggestions. I did the acoustics and sound systems of a few nightclubs back before I decided to work mostly in recording.
I'm no expert in this kind of sound deadening but what comes to mind is the deadness in a new house under construction that just had insulation installed but not yet drywalled. Very anechoic. It could be quite cost effective to line everything with R-20 rockwool or even fiberglas pink and cover that with some kind of fabric like upholstery. Probably about $20 grand or so.
