Hi everyone. I want to build a TPA3116 kit and include a couple bells and whistles that are a different voltage. I need help with that.
Here is the kit, which requires a 6-24 VDC power supply. I have one that's 19.5 DC:
http://www.ebay.com/itm/161905842097?_trksid=p2060353.m1438.l2649&ssPageName=STRK:MEBIDX:IT
Here is what I would like to add to it: http://www.ebay.com/itm/121855348210?_trksid=p2060353.m1438.l2649&ssPageName=STRK:MEBIDX:IT
Note, that I could probably just use a 15 volt DC power supply and slice that power to this. That might be what I do, but I'd get a little more wattage on the output if I use a step-down from 19.5 VDC to 10-15VDC. Also, I hear that amp runs best around 20 volts.
1) So, could I just split the leads from that power supply, where it connects to the power input on the amp, and run it to a suitable step-down board, then run that to the in on the VU meters?
2) If the answer to question 1 is yes, what step down should I use. I found everything from $2-30USD. I prefer to get a kit I can build, but I'd take a simpler route if sound would be all the better for it.
Here are a few things I found. I don't know if noise is a concern, so I'd be inclined to get something audio grade, if necessary. Additionally, I might run a 15 VDC preamp in the same fashion (That's OK if my original PS amps are fine, right?) so I want the noise to not be a factor.
Another thing I'm not sure about is if I need 15VDC+- or just +.
Items here:
1) http://www.ebay.com/itm/191095436739?_trksid=p2060353.m1438.l2649&ssPageName=STRK:MEBIDX:IT
2) http://www.ebay.com/itm/201128318986?_trksid=p2060353.m1438.l2649&ssPageName=STRK:MEBIDX:IT
3) http://www.ebay.com/itm/361294992661?_trksid=p2060353.m1438.l2649&ssPageName=STRK:MEBIDX:IT
4) http://www.ebay.com/itm/371210195666?_trksid=p2060353.m1438.l2649&ssPageName=STRK:MEBIDX:IT
5) http://www.ebay.com/itm/371216179618?_trksid=p2060353.m1438.l2649&ssPageName=STRK:MEBIDX:IT
Thanks in advance for any help you can give!
Items here:
