Little Boxes for my son SPH 60X monacor Bluetooth 30W
Hi all , advices needed to choose the enclosure
I've made a first box for my son using 30W class D bluetooth wondom ( works amazing with the Frugal Horn Mk3 !!! )
so the idea is to build a main box including the amp/bluetoot board in one of the speaker ( to make a decent bluetooth speaker ... mono ) and once at home in his room plug the second speaker on a pair of anything else
At the moment ... considering monacor sph 60X ( as he already has a pair of FH MK3 Fe126En for home version )
the idea is to make a travell possible version so ....
I 've found the Alpha design , quite simple to do , that i could cut and glue this evening .... if all is ok
www.hornlautsprecher.de - solutions in sound
