Linn Karik Mk2 (laser V.out regulation info)
I changed laser, can someone confirm that there are test points to adjust the laser voltage to 1.4V also for series lower than no. 12999 or is the adjustment possible only for the Karik III series or higher than serial number 12999?
If confirmed also for mk1 or mk2 where are they, I can not locate anything on the pcb.
I've got a karik 3, but guess you're looking for info on 2
yes exactly I have the Karik 2, but I think that the Karik 2 pcb has many parts in common with that of the Karik 3...... power supply, laser and other details aside, (toroidal Vs Brilliant, Hop M3 vs M3A etc.etc.)
I think that the test points can be equivalent but I can't find them on the Karik 2 and I don't have precise indications on how to intervene if it were feasible.
