I put 17g in each big end of the 4 tapers, listened for a few days then removed it. There were hours between the with/without listenings and I don't trust my memories but it seems like there was more mid-bass with the stuffing and more deep bass without.
The boxes are lined with two layers of 60/40 wool batting.
Not stuffed in this pic.
Can you post your opinions on the general effects of too little, too much or no stuffing?
Thanks, Mack
Thanks, Mack
Never mind. I know it's an unanswerable question because of all the variables.
I put 10g of teased fluff in each wide horn end, sealed them back up and primed.
It is somewhat unanswerable unfortunately without going into a considerable amount of detail. About all that can realistically be said as a general rule (this applies to any box) is that the more damping you add, the more you will damp the output of the enclosure.
