SY said:If the load is balanced, you can convert the cathode follower to a split-load inverter.
SY,
Will the O/P impedance of a "concertina" phase splitter be low enough to drive a potentially very nasty load? Remember, the IHF "standard" is a wretched 10 KOhms.
Should be. It's the same as the output impedance of a cathode follower, as long as the load is balanced.
Let's see, with a plate current of 9-10mA, the transconductance of a 6SN7 is roughly 2.5 mA/V. So the source Z is about 400 ohms, not too bad for driving a 10k load. An ECC88 would be better, but a 6SN7 should be fine.
denny9167 said:Could I add an additional Cathode follower stage, and "paraphrase",or use the two stages to form an "anode follower" phase splitter?
For an extra tube and higher parts count, an anode follower and cathode follower combo will offer performance somewhat worse than a split load.
MQracing said:wouldn't it just be simpler to use a small signal output transformer with a center tapped secondary winding?
small signal outputs with center tapped secondaries are pretty common in both new production as well as vintage examples being available.
I agree on the transformer, but what's the center tapped secondary have to do with it? The +/- signal should be taken from the transformer with the third connection coming from the chassis.
http://www.rane.com/note110.html
Anyhow, here's some for cheapish.
http://cgi.ebay.com/Jensen-JT-123-S...yZ113484QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
MSL
Mike, yes, you can. The conversion I suggested will cost about a dollar. I'm afraid to ask what those transformers would cost...
To be fair, the galvanic isolation from a transformer is a useful thing to have.
- Tubes / Valves
- Line-Stage w/ balanced output
