I am trying to understand how LED's work.
I have looked into the LED resistor calculator and I know what resistor I need in the circuit.
However my question is a little fundamental ...
The LED measures something like 1200 ohm.
So why does it measure 1200 ohm in both directions ? Shouldn't it measure open in one direction ? its a diode after all.
Then the thing measures 1200 ohm, put across say a 3.4v source - its correct forward voltage, it should work just fine right ? However this is what I get from the calculator -
The wizard recommends a 1/8W or greater 1 ohm resistor.
What does a piddly 1 ohm do to a 1200ohm circuit ?
Thanks.
Srinath.
Thanks.
Srinath.
