Is anyone interested in purchasing a populated two channel Leach SuperAmp circuit board (double-sided with silk-screen and soldermask, FR-4 boards). I will provide everything except: power transformer, heatsinks, chassis, optional fans. I will provide: quality brass 5-way binding posts, two 55,000UFD / 100V capacitors, bridge rectifier, unpopulated dual channel LED VU meter (LM3915 circuit), unpopulated clipping indicator and fan controller circuits, and some teflon wire if interested. I have some parts available for the unpopulated circuits. I have a choice between MJ15003/4 output pair or the MJ21193/94 pair in TO-3. I have a limited number of TO-3 sockets and SIL-PADs. I will let it all go for $550USD!!!!
Here is a picture of the original unit...for sale is the second set of untested boards (the first set worked quite well).
http://www.diyaudio.com/forums/showthread.php?s=&threadid=3751&highlight=BeanZ
