I'm still working on my two-channel Leach Amp because I've been running into several unfortunate problems. I'm hoping somebody can help me with the latest problem because I'm completely stuck. When I connect my speakers to the binding posts all of my output transistors are shorted between emitter and collector. My ohmeter reads about 2 mega-ohms. Is this supposed to happen? When I disconnect the speakers the transistors aren't shorted anymore. I've checked all of the resistors and transistors on the board and they are all fine. Any help would be much appreciated.
Thank you for your time.
Peter
Peter
