I have recently bought two Fostex FE103 Sigma for a pair of single driver loudspeakers.
I have found several possibilities in the net about using it in horns, TQWP, etc.
Did anybody of you made a PETITE (bass reflex) and can report about the results ?
I must admit that I am a bit hesitating making a more complex box when a simpler one is also working.
Klaus
Klaus
Since no one takes the bait, I feel obliged to respond.
The only impressions I have read on "le petit" were very positive.
Personally, I would choose (as I mailed you) the "Zigmahornet", a very slim, 150 cm tall pipe for the Fostex FE103s, which is supposedly very good. Drawings at: http://audionova.nu/docs/KVARTSVAG.HTM
Have you tried to ask the (very good) full range driver forum?
(http://f18.parsimony.net/forum31999/index.htm)
Regards,
Dirk
Regards,
Dirk
Petite is gorgeous
Hello Klaus,
a few years ago I had extended opportunity to listen to that speaker as a buddy owned one.
It is usable as fullrange speaker, although my buddy added a subwoofer and a tweeter soon.
It is very musical, rhythmically incredible coherent, very dynamic, a joy to listen to.
If you are after high detail resolution and complete lack of coloration, maybe the Fostex FE103 Sigma is not the best choice, no matter in which enclosure.
If you are into music listnening and focusing on music instead on hifi, it is a simple way to get to heaven. Particularly with single-ended triode amps.
Hello Klaus,
Hi Klaus,
I found quite a lot of information by one person (Martin King) who is attempting to write some software to predict the behaviour of 'transmission-line' boxes.
http://www.t-linespeakers.org/projects/martin/MLTQWT/index.html has quite a bit of detail on the designing and building of a 'Fostex FE164 Mass Loaded Tapered Quarter Wave Tube'.
Interesting reading... there is also a section on why he didn't build a 'petite' - including what his software predicted for the results.
Sorry, folks, to answer so late.
Thanks for the hints and links.
I am very busy at the moment, that is why I did not simply build the cabinets yet and listen...
One thing puzzles me:
A "normal" calculation for a bass reflex enclosure for the FE103Sigma would result in a much smaller box than the orginal two versions of the Petite. How were they calculated ?
I remember having read an article in the German mag KLANG&TON about the FE103S, that it will only have bass in a backloaded horn.
But I know that I will not get thundering bass.
I want to get a loudspeaker with the natural- and easyness I remember from the "old mono tube age" and what I still miss even in many good designs.
I think I could modify the Petite construction plans by making them less rectangelous, which is one of the main problems Martin King was highlighting (but I must admit, I was just browsing through, I have to read the article more carefully). This will reduce standing waves.
The two plans suggested at http://audionova.nu/docs/KVARTSVAG.HTM are really interesting though. I am not sure about the damping, and I cannnot understand the writing (in norwegian
Even more intersting could be a open non damped enclosure like the RONDO by Auditorium23 www.auditorium23.de (no parallel sides, resonances are accepted and used somehow). But I do not have any idea how to calculate a loudspeaker like this.
Klaus
Klaus
Concerning the Zigmahornet, this is a quote from a reply (by Pär) I got in the "high efficiency speaker asylum", with the translation of the text on this design:
Zigmahorn
A popular model with Fostex FE103Z. The box is from Le Audiophiles latest design. Incredibly good sound from a small 4" speaker.Dampened lightly with a 1" mat behind the driver. Cabinet built from 1/2".
I haven't heard them myself but know lots of people here i sweden who would swear by their mother that this is the only speaker you would ever need (though I know a few of them kicks in a sub below 50Hz). Go for it: I suppose there is about $15 in material to loose
There was a huge rave it a swedish asylum about theese (du lax lasse) where eweryone trying them jouned the choir of praise...
All the best,
Dirk
Zigmahorn
All the best,
Dirk
Oh, sorry, no insult intended, I really should know the difference between swedish and norwegian - we are all europeans at the end of the day, citizens of the world actually.
After a closer look at the "Zigmahornet" (Sigma-horn ? although it has nothing to do with a horn...) I think that it is a petite-like bassreflex construction, in a different, acoustically not uncritical form (The drawing is not very legible). This enclosure will probably have a kind of strong lenghth resonance, like a tube actually, and I tend to think that the slope at the top will not cancel this out totally. It will be very instabil, because it is so narrow and high, so it will need a broad base or foot construction.
I am tempted nevertheless. I think I am going to build more than one pair of enclosures just to try.
Can you Dirk (are you not in Belgium ?) or hifi/micke please translate the chapters of the Zigmahornet and the following TQWT for me/us ?
I am not sure about the damping and construction.
I would like to use this little beasts, the FE103Sigma, without any crossover/equalizer, as you can imagine, because I want to get rid of all the side effects, which, although I am used to that, still bother me a lot. Driving a single speaker withput passive components in the way could give the same amount of control as I can get in an all active systems. I will even accept a slight imbalance in the frequency response curve for that.
I was never really happy with crossovers, it was always like "fighting for peace" for me...
Klaus
ps:
Let me state some of the - in my opinion - most interesting different possibilities for a single FE103Sigma here (all measures in mm B*H*D):
1. Bassreflex
1.1 Orginal Fostex Suggestion for the FE103 (134*270*171 with a 50d/m*45 port)
Comment: Too small for significant bass probably.
1.2 Orginal Petite I ( L'audiophile Nr. 31 )
(353*546*227)
Comment: Not to be overlooked. The speaker is very directional anyway, so the relativly broad box will not create interferences, but the case can be constructed very strong with bracings, etc. so that the cabinet colorations will be less than with a standmounter. The necessary stands are a disadvantage nevertheless.
1.3 Orginal Petite II ( L'audiophile Nr. 41 ) (mailto:IKSchiffer@aol.com )
(210*840*250 with a 70d/m*140 port)
Comment: That is the Petite we are referring to, am I right ?
Very tempting, but cabinet colorations can be higher, which can be reduced by clever construction. My version 1.
1.4 Zigmahornet at audionova
Comment: see above
2. TQWT
1.1 TQWT at audionova
Comment: Looks very resonable. My version 2.
1.2 Solo at www.diyaudio.8m.com and other places (looks like a BD-Design originally ?)
Comment: This is a mixture between a bassreflex and a TQWT construction,as far as I can understand that, and is slightly more difficult to build. A passive equalizer is needed/suggested.
3. Horn
Cheap Trick 164
This is a hyperbolic backloaded horn designed by Bernd Timmermanns for the FE103sigma. It was published some years ago in the German speaker building magazine Klang&Ton #5/96.
Comment: It is a pain to build probably and will need a two stage passive equalizer, which cancels all the advantages of beeing coupled to the amp directly, but will offer significant more bass probably.
I have more drawings of exponential horns somewhere, I just do not find them at the moment.
To be continued...
Klaus
ps:
1. Bassreflex
(353*546*227)
Comment: see above
2. TQWT
3. Horn
Cheap Trick 164
To be continued...
An add on to your list (buschor mk2):
http://www.geocities.com/northbirdten/bh_mk2.html
Btw, I also like to read the zigmahorn translation (its simplicity is quite appealing).
JP.
JP.
I owned a pair of La Petite Audiophile for 6 years and loved almost every second of it. I built them according to plans in a Swedish magazine (Audio/Video). As far as I remember there where two different version of this speaker, one in a shoe-box style enclosure and the other was a floor-standing tall lean enclosure. I think the first was presented first and the other later as a better sounding implementation.
These speakers, in my opinion, are great for any light music and then I mean not too much bass or high energy in any area. They, for obvious reasons, do not handle high levels of deep bass very well and they have a noticable roll-off in the highs. These two quailities however also gives a good overall balance. The mid-range is great and very natural. It is great to listen to a speaker without a crossover and they are very revealing.
I'd recommend them to anybody that wants a great speaker for classic accoustic guitar music and similar. Metal freaks obviously should look elsewehere.
/Urban
/Urban
Petite L'Audiophile
I made a really small version with only 6 liters netto box volume. I had bass reflex first, but I did not like it, because bass had that one note character typical of bass reflex loaded enclosures. I filled the hole with damping stuff. Well it was then more bass-light than the first L'Audiophile version, but bass control was much better. As a remedy I made an electronic bass enhancement ("loudness"), and it played music wonderful and nothing left to be desired, at least in small room (10ft. by 12ft.).
regards,
Hartmut from Munich
regards,
Hartmut from Munich
Audiophile n°31, février 1984 "Petite" with Fostex FE-103Σ
I am looking for a commercial loudspeaker manufactured in this manner.
Thanks for an advice.
In the attachment the description from above mentioned magazine.
P.S.: must actually be filed under "Full Range"
Klang & Ton CT164 https://www.doc-diy.net/audio/horn_de/
sound not good due to many Midrange components from the horn mouth.
check out this project:
http://www.geocities.ws/dbr_audio/swan101a-nueva.html
basically the same, but additional band pass character due horn mouth facing the ground.
But the asked speaker project was both for commercial products and vented box.
AVAST gives me a MALvertizing and SPAM virus.
The only Petite Onken I knew of from la Maison de l'Audiphile was the 12" version that used an Altec 414 as the woofer. I heard it, but don't particularly remember it.
Then there was the Mini-Oken which used a 10" Focal woofer and not a horn loaded high frequency section. The mini was nice I had planned to build one, but every time I heard the 360 liter Onken with the 15" Altec, I got distracted.
Dave, Planet 10 makes very small Oken style that use fullrange Fostex drivers. Also very nice sounding.
- l'audiophile PETITE
