I recently scored both a LAT500 and LAT700 subwoofers these are the tymphani line array transducer subwoofers and I need to decide which to keep. supposedly the 500 is equal to two 10" subs and the 700 equal to two 12" subs. I need to come up with some cabinet plans for each of these and do some in room testing.
I see madisound is selling the LAT700 and has some basic cab info. but i am curious if anyone else here has played with these??
Zc
Zc
From the preliminairy data sheet on the tymphany site, Sd based, the LAT500 appears to be like a 12", the LAT700 like a 15".
The LAT700 has a bit higher Qts as the LAT500), but the voice coil winding depth and gap height for the LAT700 seem a step up in comparison with the LAT500. Both seem suited for a closed box, with such a high Qts and lowish Fs, I think that an reflex port might not even be neccesary to get decent low end performance. I think WinISD Pro could aid in your quest.
Best regards Johan
Best regards Johan
