Hi My name is Richard. I live in New Zealand. For a while now I have been thinking about building a large screen projector using either LCD panel(s) or lasers. So I looked everywhere for LCD panels prices information etc and found they were quite expensive.
I had on hand a rotating polygon with 6 facets, a 5mw red laser diode and a few first surface mirrors.
I thought build a small laser system and see if it works and if it does scale it up.
First problem. How fast does the polygon have to rotate to display a raster. We have a 625 line system here using interlace. The line rate is 15625 Hz. There is one full frame (625 lines) every 1/25 of a second so the lines per second is 625 times 25 equeals 15625 times 60 to get lines per minute equeals 937500.
This means if I had a polygon with one mirror it would have to rotate at 937500 revs per minute.
My polygon has 6 mirrors so speed drops way down to only 156250 revs per minute.
My polygon ex a laser printer said it could do 7701 revs per minute. Big difference between 156250 and 7701 rpm.
This problem seemed insurmountable however if I had a polygon with 625 mirrors each rotation of the polygon would be drawing a full frame of 625 lines therefor its speed would only need to be 25 frames per second times 60 equeals 1500 revs per minute. Well within my polygon speed range. There are no polygons available with 625 mirrors but what if I used stationary mirrors instead of rotating mirrors.
I did not fancy the idea of cutting and mounting such a large number of mirrors so how about using the 6 mirrors on the polygon to assist the stationary mirrors. That way I only need 600mirrors approximately divided by 6 equeals only 100 mirrors at 1500 revs per minute. Still too many mirrors. 50 mirrors speed goes to 3000 rpm and 25 mirrors speed of the polygon becomes 6000 rpm.
I tested this out with 5 mirrors arranged in a radius around the polygon in a special way which I will describe later and obtained 5 raster lines on top of each other. A slight tilt of each mirror gave me a 5 line raster.
That showed the idea was feasible and would work. The mirrors only have to be small about 1/2 an inch square.
I will be fitting a frame polygon so the mirrors dont have to be tilted but that one operates at a reasonably low speed so I am not worried about that.
Part 2 tommorow enough light. I have not solved this problem yet but will post how far I have got.
Richard
Richard
laser projector
Before getting on to the light aspect I should mention an advantage of using a rotating polygon in conjunction with a small number of mirrors.
The first advantage is to lower the speed required from the polygon from very high rpm to the much easier speed range of 6000 rpm.
Second advantage A polygon with 6 sides covers an arc of 120 degrees
360/6 times 2 equeals 120. This wide angular coverage was much too great because, using a laser beam I thought I would project directly on the screen 18-20 feet 6 meters away without needing a projection lens.
To check this I approximated the required angle using two string lines and a protractor and it came to 10-12 degrees.
By a happy coincidence the polygon with surrounding stationary mirrors as descibed previously also put out a deflected beam of 10-12 degrees sweep.
So far I was quite happy with progress. The polygon could be used at low speed and the sweep angle of the beam was the correct angle to put a beam from one side of my projection screen to the other.
LIGHT
The next thing was, could I get a visible raster with a 5 mw laser diode. The short answer is no. With the curtains drawn and all lights out and testing at midnight in pitch darkness I could easily get one raster line but as soon as I tried for several raster lines the beam faded away and became invisible. I had thought that persistence of vision would allow my eyes to retain the image of a raster line sufficient to see some sort of a raster. No visible raster at all. Very disapointing that was. Moving the screen to 4 feet from the projector gave me a raster but the raster was only a foot wide. And the beam from the laser diode was far too thick and not a good round beam. A little bit more light and I would have had a raster. Need more work on this.
I now had 3 options
1 Forget the whole thing
2 Buy a much more powerful laser
3 Use a powerful white light source.
1 is out. 2 is out because powerful lasers are expensive, use a lot of electricity, may need cooling water supply and can be dangerous and I would need 3 one for red blue and green.
I thought about the new high power leds that Vince tried in his DIY LCD projector. While thinking about a suitable light source I hooked up my 2000 watt electric heater to a pair of carbon rods. When the rods were touching the heater worked normally. I left the heater on for a few minutes to heat up and then separated the carbon rods. An arc formed with a tremendous brilliance similar to a welding arc. It is advisable to take all electrical safety precautions when doing this including eye protection with a welding helmet because there is a lot of UV from an arc. Arcs can also form carbon monoxide so be very careful with ventilation.
I positioned a headlamp reflector close to the arc and got a very strong beam of light which just about burned the wallpaper off the wall.
What I need for this laser projector is a very powerful light source. It must be from a point source so I can collect/collimate or focus to a small spot and it must stay as a small spot until it hits the projection screen 20 feet away. Also the light has to be divided into three colours red green and blue. These colours have to be modulated and then recombined back into one beam to go through the mechanical projection equipment.
There are numerous point source arc lamps available but are expensive, need correct control gear, probably need a fan for cooling and do not seem to last very long.
At the moment I am investigating a system which collects light from many small light souces such as car headlamp bulbs and guides the collected light to a glass fibre. This is the reverse of lighting systems which illuminate signs evenly from one powerful light source.
I think I will buy a red laser diode about 100 mw to replace the 5 mw laser I have been using and continue testing. Might even buy a green pointer. I want to see a full raster at 20 feet, I have to modulate the laser diode with video to see a picture and I have to prove the polygon and mirrors are working correctly.
Richard
LIGHT
I now had 3 options
Richard
MIHALY-TRAUB SCANNER
This type of system you are proposing was first invented in the early 1930's. I am interested in mechanical television and so thought about using some old technology such as this. Here are some links regarding some early systems. They give good technical info
Mihaly Traub
http://pyanczer.home.mindspring.com/Tour/mhalytrb.html
Mirror Screw
http://pyanczer.home.mindspring.com/Tour/mirscrws.html
VIBRATORY SCANNERS
http://pyanczer.home.mindspring.com/Tour/vibrscan.html
This type of scanner could be made with a programed chip the produce an of signal that could drive the electromagnets so you don't get a sine wave shading effect.
Scophony System
http://pyanczer.home.mindspring.com/Tour/scophony.html
The Eidophor Television System
http://pyanczer.home.mindspring.com/Tour/eidophor.html
Hope this helps, I think the vibratory scanner is the most promising. I will be starting work on that in the next 2 weeks.
Mihaly Traub
Mirror Screw
VIBRATORY SCANNERS
Scophony System
Thanks for the info Fiat1
Peter Yanczer's site is most interesting as are the others you listed.
One of the problems with mechanical Projection is the much higher line rate used today. Early mechanical projection television rarely went over 180 lines. The Scophony system could go to 405 lines and even higher.
If you haven't done so already, having a look at US patent office database is useful.
Many thanks for your posting.
Regarding my small scale laser projector,(5 mw red laser diode) I am getting ready to test out the polygon speed, stability etc by modulating the laser diode with a 625 line horizontal sync pulse. If all goes well I am expecting to see one very small gap in a raster line corresponding to a sync pulse. I am hoping there is enough polygon speed stability for the pulse to sit on the line without moving left or right too much. If it does I could then look at a start of scan from the laser into a detector compare its position with the tranmitter sync pulse and try and lock the motor at the correct speed and phase.
Will report later.
Will report later.
Hi !
This is a cool project, but i think that your first idea to use Laser was right...
I had post a reply in the project of diy videoprojector wich use lcd, and ask why not a DLP or Laser,
A student in Paris i had met on a list was working on the same thing, he use a Laser tube of 5 or 8watts.
If you want to make as good as a Tritube, you will need more power than 100mw...
But the laser as an advantage, for large screen the spot of the laser will be very small (little dispersion of the spot) and the resolution could be better than all existing systems, there is also laser tubes wich can be modulated for several colors, if the modulation is quick, we could use only one modulated tube. It may be expensive but high quality !
Pa
Pa
Sync
Early television rarly went about 180 lines due to limited bandwidth. The motor will have to be synced some how to either the horizontal or vertical picture frequency. I have long been a hobiest in mechanical television and have buitl many expamples of early televions, it is very exciting to build a cammera and reciver and get television pictures on them! Laser projection ususally works by servo and has two to produce the raster. I still think that a vibratory mirror would be the best, it is like a DLP but using on mirror to do the whole lot, look at my previous post for a link.
Colour
You should produce colour with a 3 colour wheel to make it cheaper ans possibly easier. You can not modulate light at such high frequencies as modern television uses. That is why the scophony system has a jeffer cell to do this. Modern laser projectors do this:
Light Modulation
Once the proper red, green and blue beams are produced, each must be modulated with its correctly decoded video signal. This is done with one acousto-optic modulator for each beam. An acousto-optic modulator operates by the interaction of a very high frequency sound wave traveling through a crystal material. The laser beam passes through this crystal at approximately 90 degrees to the traveling sound wave. The sound wave is varied by the incoming video signal causing distortions in the crystal and the light diffracts off the variations as if they were, in effect, a solid diffraction grating. The angle at which the light is deflected is very small and different for each color and the light is only deflected when a video signal is present. The electronic circuitry of the projector supplies the individual red, green and blue signals to the modulators in response to the video input.
Light Modulation
Pa Thanks for your post. The reason I am at present using only A 5 mw laser is to make a small scale projector, see if it works and if it does then I can think about scaling it up.
Fiat1 Thanks for your post. You hit the nail on the head when you said it is exciting to make these things and actually get them to work and not only work but sometimes work better than commercial products. Things have changed a lot from when a group of us used to build our own Hi Fi amplifiers. All valves like output tubes EL84 6v6 EL34 KT66 and KT88 even 807 transmitting tubes. We had one big advantage then. There were far more stores catering for DIY projects and most electronics magazines had heaps of circuits. The parts themselves were not all that expensive and guys would turn up at my place with huge amplifiers 4 KT88 output stage which were so heavy. One chap even built an amplifier with no output transformer using 40 6v6 output tubes. Worked too.
Today I find not so many shops catering for the DIY enthusiast and magazines more interested in advertising commercial products. Changes happen and you got to work with whats available but the internet is a great thing where people share their ideas with others.
As you said, DIY is really exciting.
1 or 3 rays...
If you use only one ray (all colors output mixed on the same ray), and not 3 separate rays, you could set the size of the screen with a "zoom" or move your videopro, if you use 3 rays (like crt's) it will be harder because you have to modify angles of rays and convergance will be long... (i know this i'have a crt videopro..) this could be an advantage for laser projection compared to crt's.
1 o 3 light sources.
3 light source -> easy settings of colour balance, (could be laser or 1 white lighte source and filters ? (not laser)
I don't know But with 3 source you can imagine both a red and blue ray simultaneously...
ah... other thing, someone said me there is a lots of patents and the subject published in big us databases in us patent office and maybe IBM. Not useable for commercial applications but super for diyers
maybe you should take a look at this.
Further progress on my small scale laser projector.
As mentioned above I was going to try and get a sync pulse on a raster line for two reasons. To see if my speed calculations were close and see the free running speed stability of the polygon. Ok did that and it worked. Here is how. First I needed an accurate source for a sync pulse. I tried my video tape recorder but my scope had trouble syncing to that so I figured the vcr was not a rock steady source. The video machine was a bit old. Next hooked up my television. That was composite video with not only H sync but all the video information. I happened to have a tv pattern generator which did turn out sync plus video and sync pulses only. Checked with the scope the pulses were rock steady. Boosted the sync pulse with a transistor and connected to the 5 mw red laser. I run the laser from a 24 volt supply via a 330 ohm resistor and a milliamp meter to see the laser current. That way you can turn down your power supply to avoid any possibility of eye damage. Usually run the laser at 50 milliamps but it will go to 90 milliamps. Supposed to handle 100 milliamps but I keep it well below. Anyway applied the sync pulse modulation to the laser diode, ran up the polygon system with a single mirror. Got a normal full line raster and by adjusting the polygon speed to 2000 rpm the full raster line changed to 4 small segments with 4 even smaller gaps. The line segments were about an inch long and the gaps about 1/32.
Now set the polygon motor speed as finely as possible to make the gaps stand still on the raster line and watched as they moved only slightly. Conclusion. The polygon speed stability was pretty good considering it was free running from my signal generator. The polygon speed is well below my calculated speed in the 6000 rpm range but I am pretty sure speed stability will increase with higher speed so not too worried about that. Probably need Xtal control motor speed and compare and adjust phase to align with incoming sync pulses
So far progress is good.
I have some sticky problems coming up.
1 How do you handle interlace with a mechanical system
2 Should I try for 3 high power lasers
3 What about laser speckle
4 Laser modulation is going to be a problem
Since this DIY project is still in the small scale range I will think about the interlace problem next and report progress.
Have read the incoming posts for which many thanks.
Progressive projector...
Why do you want to interlace your videopro ?
The dream of videoprojector fans is to have a progressive videoprojector, my next buy 'll be an RVB interface board for my Sony Crt's to connect it to a PCHT.
I think in a first time the use of a pc for generating syncro could be a good solution, you can modify resolution, vertical and horizontal frequencies and customize or optimize frequencies to reach the top of your diy videopro, use pattern generators, or even make special pattern animations for testing.
Powerstrip coud be an useful software !
In a second time if you don't want to see big lines on your screen :-( you could use DScaler to deinterlace and scaling.
It's opensource and a lot of people seems to be happy with it...
http://deinterlace.sourceforge.net/downloads.htm
Hope it'll help.
Pa
Hope it'll help.
Pa
brightness
I think you're underestimating the problem of getting a bright enought point light source. It can look amazingly bright, but once you start spreading that point over 625 lines, then each line gets only 1/625 of the brightness... then each point on the horizontal line gets a small part of that 1/625. big problem. but, I still like the idea
I kinda gave up because of this as well as the rotating speed, and I hadn't thought about a mirrored polygon, so good thinking there!
Also, what kind of motor are you using? a stepper motor would probably give better speed control, but I'm not sure how good they are up at 6000rpm. also a flywheel would probably help with speed stability a lot.
as for the light source... I don't know much about lasers.. how expensive/bright/hot are they (meaning something that might be applicable here)? also, do they come in red/green/blue, or white?
yes... problem of the light source is the main problem not technicaly but economicaly...
a few watts laser is necessary, and you need an atomic generator to feed it.. a guy was doing this kind of thing with a laser for music shows, a lots of pieces like motorized miror or rotating lenses, or even laser tubes exist for this aplications. prices are certainly lower than fews ago, and it'll be fantastic to use lasers wich are so pure. If we have to use color filtered white source and colimated rays, is it realy more intersting compared to DLP ? i'm not sure..
Pa
Pa
Thanks for information. I know the light problem is a big one, as you say a bright source spead over the lines then further subdivided over the points on the line makes for a very small resultant. Is'nt persistence of vision going to help a bit. Drawing a frame from top to bottom in 1/25 th of a second should be fast enough for the eye to retain some of that image for a period of time. I have read several posts where people have taken high speed photographs of a television screen which show half or more of the screen completely black the phosphors having faded out yet the human eye still sees a complete top to bottom picture. I am hoping persistence of vision will keep some of the picture visible even though the scanning beam has moved on. It still doesn't alter the situation that more light is better. While working on the mechanical system I have been giving the light problem some thought. Coat the viewing screen with white phosphors that will show a light gain when hit by a beam of light. Could be feasible but would limit me to black and white picture. Use a uv souce and cover the viewing screen with luminescent paint. Might work. Use a full individually addressable laser bar top to bottom and scan it horizontally. This project is a small scale system. If I get a visible raster I will be happy. If I get a picture however dim I will be happy. But not for very long. I will soon be looking for a brighter light source. In the meantime interlacing is a problem. Should I solve that by mechanical means or hook my tv up to my computer and use the board VGA output in non interlaced mode. Further information soon.
persistance of vision
From what I understand, the persistance of vision will help it look like one complete image instead of a sweeping collection of dots, but will not help any dot look brighter. I think the most similar example I can think of is an analogue oscilliscope, which is just one point trace on a phosphor screen. when you set it so that the beam points on one spot continuously, you see a very bright dot. then when you give it a signal that makes the scope wiggle, you see a bigger picture, but each line in that picture is considerably less bright than the one dot. persistance of vision or not.. I don't know exactly what that does with brightness, but I know that the scope is dimmer when its spread out.
as for interlacing, why do you want to do that? I'd recommend the vga card or some similar type of controller.
Evan
Evan
If you're looking into lasers...
There are several types of lasers you could use. First off, theres the red 5mW, is that a helium-neon? Once you get to 100 mW helium-neon's are very large and extremely expensive even at surplus prices. You could go for an argon laser, which can sometimes be found on eBay for decent prices. This laser puts out 488 and 512 nm wavelengths (blue green, respectively), these don't usually need a water supply but they do have fans, which can be noisy.
There are also krypton argon combination lasers which can in turn put out the entire light spectrum, combined white. Although a laser projector is possible, high quality lasers can be extremely expensive.
Greetings. I agree that persistence of vision will not make any dot brighter than it was originally. One of my original experiments was to set up a system as used by a mechanical television pioneer Ernest Traub in 1936 which used a rotating central mirror and an equeal number of stationary mirrors as tv lines. I used only one mirror but still obtained one (barely visible in a darked room) raster line even though the line was not refreshed for some time until the central rotating mirror came around again. It made no difference the speed of the central rotating mirror, still the same light level.
- General Interest
- Everything Else
- The Moving Image
- DIY Projectors
- Laser projector
