I'm currently running an Eminence Lab 12 in a 3.5 cubic ft sealed box. Works fine. I'm wondering if a 12" Ultimax would be an improvement or not. Classical music, not for home theater.
Lab 12 is fine. You have less power for more sensitivity vs. the Ultimax 300W for Xmax (vs. the 90W @Xmax Lab12). There's no interest in that change as far as I'm concerned, unless you get other factors. What's the xover frequency? Is it for moderate SPL?
Thanks for the reply.
x/o is around 60Hz 24db LR. Maybe 70. I'm fooling around with it. I occasionally push it, but for the most part, orchestral and opera played at reasonable levels.
If using a "small" amp the lab12 plays a definitive role. The curves in frequency are not the same but differences are minor only visible if you simulate drivers.
