Ive had this amp off and on my workbench for the past few weeks; poking through I originally found the TIP2955 output had failed in the right channel. After replacement, the channel looks clean on the scope w/o a load. As soon as I attach a test speaker the channel gets distorted.
Ive seen this before with other amps, where the driver transistors had malfunctioned, however this amp has proven to be a little stuborn and I'm unable to locate the faulty component(s).
The output that was replaced was Q8R (Top of photo, left output). From what I can tell, all the smaller transistors test OK, and some I've even swapped left-right channel. Not one found yet to be the cause.
I think otherwise, this amp should be a pretty quick an in-expensive fix
[IMGDEAD]https://i886.photobucket.com/albums/ac65/unclemeat2010/alpine/IMG_20101223_093557.jpg[/IMGDEAD]
[IMGDEAD]https://i886.photobucket.com/albums/ac65/unclemeat2010/alpine/IMG_20101223_093545.jpg[/IMGDEAD]
[IMGDEAD]https://i886.photobucket.com/albums/ac65/unclemeat2010/alpine/IMG_20101223_094141.jpg[/IMGDEAD]
