Kunthrandum - OpAmp biased MOSFET amp
The simulated currents at both mosfet sources are shown in the figure. Using 1Vp-p, 10kHz at input, I found no problems. Please give me more details about the cross-conduction problem. I'm using LTspice here. What was the voltage across bias capacitor..?
Sometimes I get starting problems which could be eliminated by starting the 'quiescent current adj.' voltage from zero.
Version 1.2
Heyyy...
SORRY... I saw high cross conduction when I simulated the circuit with High gate capacitance mosfets, feed with a High-High signal (30Vp-p@200kHz). The circuit will smoke.
I've modified the circuit and posted it on my website. Now it is OK in such conditions. Using current mirrors instead R15 & R16 in the previous circuit works also.
Please donate...
