So I've acquired some Klipsch pro media 2.1 which are apparently not working (nothing heard out of any of the 2 speakers or subwoofer) ....whipped the backplate off - nothing scorched inside (always a plus), so now want to start troubleshooting.
I'm figuring here that since there's neither speaker working nor the sub, that it's likely a power supply fault or a preamplifier fault.
Here's the whole list of internal module schematics...
New Version Klipsch Promedia V2.1 Amplifier Repair
& here's the actual power supply (click to enlarge)...
Explanatory words of the wise here...
I'm figuring the CN2 connector voltages (+39V & -39V) & CN3 connector voltages (+27V & -27V) are the first port of call for troubleshooting? (just got to rig this up to 110V AC....cos I'm located in the UK & our wiggly volts are bigger than your wiggly volts)
(don't be alarmed...I do realise there's some chunky DC voltage (300V+ on C2+ to ground) on that SMPS so I'll proceed carefully!
"The AC mains voltage passes through a small line filter and is then rectified to give approximately 340 Vdc for primary-high. Leaving off J9 configures BR1 for bridge rectification when the AC mains are 240Vac; stuffing J9 makes the bridge act as a voltage doubler when the AC mains are 120Vac, and gives the same approximately340Vdc. Primary-high is stored on a pair of series 200V electrolytic caps.
Resistor R7 and D1 deliver the initial voltage from primary-high to turn on the controller, U1, living on a daughterboard. Transistor Q2 and ZD2 form a discrete regulator to power the controller IC. Diode D4 prevents backwards current from flowing into the regulator. Once power is applied, U1 generates a 50% clock set by R21 and C28. Each clock state generates a high pulse on HO or LO, the isolated gate driver outputs, with a fixed deadtime inserted between pulses. This simply alternates turning on the two half-bridge transistors. Diode D8 and C22 form a bootstrap circuit to turn on the upper FET, recharging the cap when the lower FET is on.
The switched-mode power supply (SMPS) on the main SMPS board is a simple half-bridge, resonant, unregulated circuit. Each gate drive output goes through a gate resistor with ananti-parallel diode. The FETs, Q5 and Q7, alternately turn on, chargeing and dischargeing the transformer primary winding, T1:1. The resonant action of the supply is created because the current through the transformer primary must flow through either C3 or C5. This creates a square voltage waveform across the transformer primary with a sinusoidal current. This supply is very efficient as it uses zero current switching to (nearly) completely avoid switching losses. It's also excellent for audio applications because the lack of regulation isn't a detriment in the face of the high crest factor of audio signals. Finally, the square voltage waveform provides consistent, reliable output voltage.
During normal operation, T1:2 also gives a square voltage waveform which is rectified by D3 to supply the controller with operating voltage, relieving R7 of this duty.
Each secondary winding (T1:3 and T1:4) uses dual series rectifier diodes to bridge rectify the winding's voltage waveforms into a stable DC voltage. A small inductor filter reduces noise"
