kicker kilpsch or.....
I am building a Home Theater sub woofer. I would like to go with an 10 or 12 inch driver. I don't have a whole lot of money so i was looking on eBay at Klipsch replacement sub drivers. Then I discovered that kicker makes large sub drivers for cheap. I assume that there is some bad side or maybe it is just bad for home audio? Any help would be appreciated! (FYI my budget is right around $60)
Thanks!
I'm using a Kicker 08S15L74 in a T-TQWT (negative flare tapped horn) for home theater use. I built the enclosure in 2013 and it's still going strong as is.
