ZD9 is an 18v zener diode,R73 is a 10 ohm resistor (1206). R73 carries the battery terminal voltage and ZD9 insures that IC13(opamp for auto ton) and IC19(auto and high level on) do not exceed 18 volts. Changing these parts should take care of this problem.
R273,274 are 16 ohm zobel resistors, and most likely burned up due to oscillation in that channel.
Check R176-27 ohm and remove R174,274,R173,273 & R176 and power amp and w/o signal check with an oscilloscope. You will see low level oscillation or ac voltmeter on speaker term/s and the drive to the output inductors will show a square wave with obvious jitter, as if there is a small amount of signal.
C229,230-22nf and C231-3.9nf may be the culprit. Because you are seeing this on one channel only is a good sign that this is the case.
