Not fully versed on what is meant by "deflection" on an oscilloscope. I wasn't sure how I could touch the B+ terminal and monitor IC6 pin1 at the same time. I connected probe 2 and touched that one to B+and the waveform on IC6 pin1 started to shake like there was an earthquake but there was no interruption or change in amplitude, just shaking. The top and bottom of the waveform is still of the top and bottom of the screen at 5V/div.
When I turn the amplifier off, on 5V/div, the waveform shrinks down into the screen to approximately ±4V for a second just before disappearing as the amp shuts down. That's the only time pin1 of IC6 has a triangle waveform of approximately ±4V.
