KENWOOD KAC 7252 CAR AMP
First, I recommend opening the amplifier to see if you notice any fried components. When resistors blow, they can leave a black mark. The good news here is that the problem might be rather simple given that it is going into protect mode.
The repair might be more costly than a new amplifier though if you have lost some output transistors.
You might want to wait to see if Perry replies. He's far more knowledgeable when it comes to car amplifiers than I am.
There are 8 large transistors clamped to the heatsink on this amp. Measure the resistance between the 3 legs of each of the individual transistors. Do you read anything near 0 ohms between the legs of any of the transistors? Try all probe/transistor leg combinations for each transistor.
Thanks for the reply, I checked the resistance between the legs of all the output transistors there is some kind of resisstance between the legs. I have managed to download the schematic of this model.
Please advice what should i be doing next.
