When i try to power this amp up the power light will come on for 2 secs then shut off..
Heres what i get on the 494
Pin 1:2.54
Pin 2:0.56
Pin 3:4.63
Pin 4:0.31
Pin 5:1.48
Pin 6:3.58
Pin 7:0.00
Pin 8:13.79
Pin 9:0.00
Pin 10:0.00
Pin 11:13.79
Pin 12:13.79
Pin 13:4.94
Pin 14:4.94
Pin 15:4.94
Pin 16:0.00
Any ideas what might cause this?
Pin 1:2.54
Pin 2:0.56
Pin 3:4.63
Pin 4:0.31
Pin 5:1.48
Pin 6:3.58
Pin 7:0.00
Pin 8:13.79
Pin 9:0.00
Pin 10:0.00
Pin 11:13.79
Pin 12:13.79
Pin 13:4.94
Pin 14:4.94
Pin 15:4.94
Pin 16:0.00
Ok got the amp to power up..
Heres what i get on Q1
Leg 1:0.00
Leg 2:45.6
Leg 3:0.6
I replaced that regulator and still dont get 15 volts on the 3rd leg.. Any ideas ?
Leg 1:0.00
Leg 2:45.6
Leg 3:0.6
Did you pull one leg of R3 out of the board when you checked it?
Either something is preventing it from pulling the voltage up on the diode and capacitor or it's well out of tolerance.
You're going to have to find what's dragging the voltage down. The diagram only shows the Zener, the capacitor and the base of the transistor connected to the resistor.
There is no regulator. The transistor, the zener and the resistor work together to regulate the voltage.
The transistor is a 2SD2012-F. The diode is a 16v zener.
- General Interest
- Car Audio
- Kenwood KAC-7202
