Hi there,
the foams are either there or disintegrated. If they are solid, then they should function ok. In any case, the foams have very little effect in dampening the woofers. It's the spider that takes care of that.
Not sure what you are referring to by crossover frequency. Can you be more specific? The coupled cavity causes a resonance in the 180Hz region and the crossover is tuned to reduce that, and make it flat.
The combination of the woofers and midrange (B110) response should be flat merged together.
You can take the KUBE out of the equation and see how they fare without it. IIRC, it should give you a slightly reduced response in the low end and a higher rolloff frequency.
The first point I would check would be the capacitors in the crossover. I would unsolder one lead and measure them with an LCR meter. They should not match their rated value necessarily but be close around it.
SaSi, thanks for your response.
I will check the caps - recapping my vintage gear always brings back the bass so maybe it's a similar problem here...
Here are the frequency responses with and without the Kube. These are measured from about 9' exactly centered with an Umik 1 mic, REW software in a lightly treated living room. The individual Left-Right speaker measurements (not attached) produce the same curves.
The pronounced bass rolloff seems to follow the crossover frequency between midrange driver and low drivers. The Kube at maximum Contour provides bass boost as well as a flattening around 2khz as I had read it should, but clearly the bass is still a problem.
Also, there seems to be a natural "house curve" from 700hz - 20khz, but I am running the audio flat directly from a Benchmark DA into Adcom power amp. It's possible this is room effect, but I am wondering about the tweeters. Any thoughts on this?
Two more quick questions as I am new to this forum, if you don't mind.
How do I get at the woofers? Also, is there somewhere online I can find a parts list or schematic? I would like to preemptively order new caps. These units are from the 80s and received very little use so I do suspect the caps should be replaced.
Thanks for the help!
