Ya, this is my first go at an amp. I'm learning as I'm going... it's a slow process, but I'm chatching on little by little. I built up the amp stock on the breadboard, now I'm moddding it and putting it in an enclosure. I've attached a picture so you can get an idea of what I'm doing. The power trannie will be mounted underneath, but I'll leave the output trannies on top. The sheet is 8x12. You could probably go smaller, but with the tighter space you need optimal planning and layout (I have little of both).
[IMGDEAD]https://farm3.static.flickr.com/2241/2195363621_77361bf4b7_o.jpg[/IMGDEAD]
