Jung regulator with fast output start
HI,
My jung super regulator output when turned on:
First 1.6V and then raises to 5.0V after 1-2sec
I need for my Squeezebox 3 (used with coax output only)that the PSU start with 5V on the output
Is it possible if I remove the Pre regulator that the super reg starts with
5V instead of first 1.6V on the output?
Will I loose any performance?
Kim
HI,
Kim
Is it the prereg which comes up delayed or the superreg?
How much current are you trying to pull from the SR?
Squeezeboxes draw quite a lot of current and as it is, the Jung SR is set-up for 300-500mA. Beyond that - the output transistor can cope fine, but you need to increase the bias of the current source a little to ensure the output transistor is driven hard enough. Without that the voltage will not sustain high loads, or heavy start-up load transients.
Alternatively I wonder if your pre-reg is going into current limiting, hence the slow start.
Note the Jung SR itself does not have a start-up problem - indeed, the CCS bias makes it turn-on hard when you apply power, to make the error amp startup-up fast and pull-down the output. Leave the onboard caps at the value recommended.
That sounds like my situation.. I have split the supplies in the SB3 so I supply the display with the default switch mode with current use around 0.5A and the digital part with a jung regulator (sjostrom PCB) 5V/ 0.3A
You can read about the split on the dungeon hifi page🙂
I will measure some more and get back soon.
Thanks again
Well, yes, though not the iteration you have, which is actually an aftermarket interpretation of the Jung SR topology.
It would be worth you trying yours bypassing the pre-reg, to see if the issue you have remains; i.e. - whether the pre-reg is the cause; or if the pre-reg's output is rising slowly because the SR part cannot cope with the load start-up transient. Or you could ask your supplier once you've identified the problem load case...
