Jumper Wire Gauge and Material for Phono Preamp?
None of that matters a great deal. If you are carrying filament current in a wire, you decide how much voltage drop you can tolerate and make sure its resistance is low enough. Typically, for short runs up to an Ampere, you can use 20 AWG but if you want to be safe you can go a little bigger. Insulation is unimportant as long as there is no danger of shorts. And always use copper unless there is a reason not to.
There is so much mythology in this stuff. Use common sense and you will do fine. No magic.
