As part of refitting the lounge, I have a shelf which will run below a bookcase, giving me the option of building a bass speaker into the room. (The shelf was once a platform so it is structurally solid.)
I'm intending to use one or more Jordan JX125s (I have four) and the space available gives me the option of 2 units in a MLTL (GM's design from the Jordan site ) or a single unit in a BIB.
The aim is to have something which will be rolled off above 80-100Hz (depending on the main speakers used). I am a little cautious as I don't like bass which booms and it's a corner position. The MLTL seems tunable and could be built with the port away from the corner. The BIB would, of course, be floor loaded rather than ceiling.
Sketch attached. The blue box is the shelf (it's long enough for two MLTLs but s*d's law, the lounge layout is fixed by the staircase - the grey box). Red boxes are the main LS positions, fetching green box is the listening position. Room size is 19 x 12 feet and all timber/stud wall construction.
Any input from GM and the BIB-sters greatly appreciated.
