I did a simulation today using a PN4303 (halfway decent audio FET with reasonably low noise and fairly low transconductance). With the standard model in ORCAD, a 680 ohm source resistor and a 6.8k drain resistor gave me a gain of almost exactly five. For 200mV in (1V out), I got 0.3% THD, almost all 2nd and 3rd harmonic. This agrees pretty well with what I've gotten in real life. With these values, the drain voltage was fairly well centered using a +30v supply. For real - life FETs, you'd have to select devices or jigger the values around for proper gain and output voltage centering, but the results look reasonably encouraging. Last time I looked, Electronic Goldmine had the PN4303. Mouser also has them from Fairchild and Vishay. If you go this route, I'd spend the extra money and opt for the Vishay devices.
BTW, you never really mentioned wheter you wanted a gain block or a buffer in front of your clone, though since you originally cited the common source amp, I assumed the former. If you want gain, how much?
