Jeff Bagby's Kairos woofer modules, which woofers?
Hi All
I have a pair of Jeff's great Kairos 2 way stand mount speakers, and just as I was getting ready to order a pair of his woofer modules kits, Meniscus sadly went out of business.
While I am sorry to see them go, they do not seem to have made provisions to publish any of the speaker kit designs.
I am not even sure which exact SB Acoustics 10" woofers these kits use. Does anyone know which models they are?
I can design the crossover to connect them to my Kairos myself.
Thanks!
Hi All
Thanks!
I had the same question, good to know it's the 6ohm. I'm using it in a 3-way build so decided to look in to Jeff's woofer module as a good starting place for crossover design.
Have you had a chance to design a crossover? When I put Jeff's recommended low pass crossover network into software with the SB29 it seems to result in a 3db peak at 70Hz and a minimum impedance below 3ohm.
